Configure Auto-sense to Create All Learned Tunnels in the Remote AreaNEW!
You can only use this command on a switch with boundary-node abilities.
Perform this procedure to create all ExtremeCloud SD-WAN learned tunnels in the IS-IS remote area. You can also configure exceptions for specific tunnels. For more information, see Configure the IS-IS Area for a Specific Tunnel.
By default, Auto-sense creates SD-WAN logical interfaces in the home area.
    enable
    configure terminal
  2. Configure the IS-IS area:
    auto-sense sd-wan multi-area remote
